1996 Lexus LS 400 console replacement
127,000 MILES • V8 • 2WD • AUTOMATIC
6533STOLL
My center leather console is worn out. I bought a used one to replace it. How can I remove the old one. I don't see a way to access the mounting screws.
Oct 28, 2010 at 3:01 AM
SATURNTECH9
  • 30,869 POSTS
https://images.2carpros.com/forum/automotive_pictures/416332_1996_lexus_LS400_console_part1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/416332_1996_lexus_LS400_console_part2_1.jpg
https://images.2carpros.com/forum/automotive_pictures/416332_1996_lexus_LS400_console_part3_1.jpg
Service and Repair REMOVE CONSOLE BOX HINT: Tape a screwdriver tip before use. (a) Using the screwdriver, pry out the cluster finish panel, and after disconnecting the connector, remove the Panel. (b) Using the screwdriver, pry out the lower console cover. (c) Using the screwdriver, pry out the cover. (d) Remove the 3 screws and lower console box. (e) Remove the 4 screws and cup holder. (f) Remove the 4 screws and the console box. Installation is in the reverse order of removal. First of all thank you so much for the donation.Here are the instruction's on removing the console.
Oct 28, 2010 at 3:16 AM
6533STOLL
After this I need to remove the hinged cushion behind the cup holder. It has a leather covered top with air vents and a compartment below. It appears to be held with (4) screws towards the back of the console.
Oct 28, 2010 at 4:14 AM
SATURNTECH9
  • 30,869 POSTS
Sound's like you have it figured out glad to hear it.
Oct 28, 2010 at 4:24 AM
