1996 Lexus LS 400
ZANDER69
Smells problem
1996 Lexus LS 400 V8 Two Wheel Drive Automatic
i'm smelling gas in the inside of my car and my car have a misfire and the check engine light is flashing
Oct 19, 2010 at 6:45 AM
  • 75,988 POSTS
Have the computer scanned for code/s-you have a problem within the engine management system that caused the CEL to turn on-This is your starting point of diagnosis,finding out what's going on.
Oct 19, 2010 at 10:59 PM
ZANDER69
my car is misfiring and i got dead plugs. i have change the plug and i still have the same problem . can you help me
Oct 20, 2010 at 11:43 AM
  • 75,988 POSTS
If no spark-do below
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Oct 20, 2010 at 12:40 PM
