1996 Lexus LS 400
1996 LEXUS LS 400
ZANDER69
Smells problem
1996 Lexus LS 400 V8 Two Wheel Drive Automatic
i'm smelling gas in the inside of my car and my car have a misfire and the check engine light is flashing
Oct 19, 2010 at 6:45 AM
Have the computer scanned for code/s-you have a problem within the engine management system that caused the CEL to turn on-This is your starting point of diagnosis,finding out what's going on.
Oct 19, 2010 at 10:59 PM
ZANDER69
my car is misfiring and i got dead plugs. i have change the plug and i still have the same problem . can you help me
Oct 20, 2010 at 11:43 AM
If no spark-do below
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Oct 20, 2010 at 12:40 PM
