1995 Lexus LS 400 replacment of digital controle unit for t
G W OUZMAN
  • 1995 LEXUS LS 400
  • V8
  • 111,000 MILES
I have just acquired my ls400 and was told by the seller that the fogging up of the unit display is a common fault .I have acqired a replacement and would a ppreciate some guidance as to remove the old unit. Thanks
Saturday, January 19th, 2008 AT 5:27 AM
2CARPRO JACK
  • 11,533 POSTS
Do you mean the a/c heater control assembly?
Remove register from above radio, remove upper shift console panel, disconnect connectors necesary for removal. Remove 4 screws. Remove radio and heater control assembly together. Remove 2 screws to seperate the radio and controller, reverse procedure to install
Sunday, January 20th, 2008 AT 8:22 AM
G W OUZMAN
  • 7 POSTS
Hi jack. Thanks for your answer to my query. My LS400 does not have apart between the air con panel and the radio. Also the shift console is in one piece.I take it that when you say register you mean a narrow strip my vehicle has not got one sorry to be a pain. Regards geoff
Monday, January 21st, 2008 AT 6:18 AM
2CARPRO JACK
  • 11,533 POSTS
Without the car, all I can do is what my software says. The radio and controller mount to each other. The register is the vents. What is the exact production date fom inside the door sill on the sticker? Differnet year might have different instructions
Monday, January 21st, 2008 AT 6:59 AM
G W OUZMAN
  • 7 POSTS
Hi jack. The date of first registration is 19-01-1995.I hope this will help. Thanks again. Regards geoff
Monday, January 21st, 2008 AT 7:59 AM
2CARPRO JACK
  • 11,533 POSTS
Is that 1 or 9 of 95?
Monday, January 21st, 2008 AT 2:42 PM
G W OUZMAN
  • 7 POSTS
Hi jack first registered on 19th jan. 1995. Any good? Thanks. Geoff
Tuesday, January 22nd, 2008 AT 4:28 AM
2CARPRO JACK
  • 11,533 POSTS
Need the production date. Open drivers door, should be a White sticker on the inner door frame or on the door where the latch is.
Tuesday, January 22nd, 2008 AT 7:14 AM
G W OUZMAN
  • 7 POSTS
Hi once again jack the date of manufacture is october 1994 hope that will do it thanks geoff
Tuesday, January 22nd, 2008 AT 11:07 AM
2CARPRO JACK
  • 11,533 POSTS
Once again? The instructions in my software are the same for either years.
Tuesday, January 22nd, 2008 AT 11:59 AM
G W OUZMAN
  • 7 POSTS
Hi thanks for your patience in tryinng to sort my problem.I realise that you can only give a limited amount of info. So I am gratefull for the help that you have given. There is one more thing that I would appreciate can you tell me how to remove the heater vent as I can't see any screws. Thanks again regards geoff
Tuesday, January 22nd, 2008 AT 12:18 PM
2CARPRO JACK
  • 11,533 POSTS
Most of the time things like that just pop in and out. The clips can be a little tight and take some effort
Tuesday, January 22nd, 2008 AT 12:40 PM
G W OUZMAN
  • 7 POSTS
Hi. Ok I will try that. Thanks again for your time, you are doing a grand job for us inexperienced morons regards geoff
Wednesday, January 23rd, 2008 AT 8:23 AM
2CARPRO JACK
  • 11,533 POSTS
No one is a moron, just inexperienced
Wednesday, January 23rd, 2008 AT 10:32 AM
Related General Content
