1994 Lexus LS 400 instrument panel
ROGERLS
1994 Lexus LS 400 V8 Two Wheel Drive 130000 miles
Question the laser light for the speedormerter comes on usally after a bit of driving 10 to 15 minutes which has been going on for about 6 months, now the last two days on engine start-up the whole dash board flickers before completely lighting up. Is this a fuse or electrical problem.
Nov 23, 2008 at 7:22 AM
WINNER155
I had a similar problem and it turned out to be a short in the left rear tailight, However, my problem only happened when you stepped on the brakes. This is not an uncommon problem in the LS 400. Look for a ground short that may be causing this,
Nov 24, 2008 at 2:58 AM
SZETO
  • 10 POSTS
Go to www.clublexus.com. Detailed instructions and even pictures for do-it-yourself (partially or totally) solutions. We fixed the problem by following the instructions and pictorial explanations.
Dec 30, 2008 at 8:56 AM
