1994 Lexus LS 400 Dash Board Lights
135,000 MILES • V8 • 2WD • AUTOMATIC
PILIA
the lights on the dash board go out, and also when they come on they flicker. This is all without warning. What is the problem?
Sep 19, 2009 at 3:19 AM
KHLOW2008
  • 41,812 POSTS
Hi pilia,
Thank you for the donation.
Such intermittent faults are usuallu caused by bad connectivity of wire connectors or meter cluster printed circuit boards.
When problem occurs, check if the exterior lights are working, if no, the lighting switch could be the cause.
Sep 19, 2009 at 3:44 AM
