Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Lexus
LS 400
Interior
Dashboard
Light
1994 Lexus LS 400 Dash Board Lights
1994 LEXUS LS 400
135,000 MILES • V8 • 2WD • AUTOMATIC
PILIA
MEMBER
the lights on the dash board go out, and also when they come on they flicker. This is all without warning. What is the problem?
Sep 19, 2009 at 3:19 AM
KHLOW2008
Experienced Mechanic
Hi pilia,
Thank you for the donation.
Such intermittent faults are usuallu caused by bad connectivity of wire connectors or meter cluster printed circuit boards.
When problem occurs, check if the exterior lights are working, if no, the lighting switch could be the cause.
Sep 19, 2009 at 3:44 AM
Add image or video
Ask a new question
Engine won't start
Engine has low power
