1994 Lexus LS 400 after tune up car stops
1994 LEXUS LS 400
265,000 MILES • V8 • 2WD • AUTOMATIC
SUMMA
after tune-up, car ran for about 30 minutes. drove down the road about a 1/2 mile to a mile, car stopped and won't start back. car is turning over like it should but won't start-up.
Feb 15, 2010 at 2:23 AM
Hi summa, Welcome to 2carpros and TY for the donation
Cranking over and will not start. Do below to determine if its fuel, spark and compression related issue
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 in away from ground have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft sensors and computer. Note: If it doesn't apply disregard it
Compression:
If both correct fuel pressure and snapping blue spark is present-check engine compression could be a valve and ignition timing, issue -this will lead you to problems with compression and valves opening and closing at the wrong time/broken or jumped timing belt/chain
Feb 15, 2010 at 8:02 AM
SUMMA
Thank you so much i was so upset because i thought the guy try to get over on me but i took it to another shop and they said what you said, so now im feeling a little better about the situation. Again thank you
Feb 15, 2010 at 1:49 PM
