1993 Lexus LS 400 stall on fast take off
96,000 MILES • V8 • 2WD • AUTOMATIC
RAYMACK
when i gas the car for a fast take off, it stall and then take off
Jun 23, 2010 at 8:44 AM
  • 75,988 POSTS
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jun 23, 2010 at 8:55 AM
