1993 Lexus LS 400 rattle up front
1993 LEXUS LS 400
174,000 MILES • V8 • 2WD • AUTOMATIC
CORNHUSKER4
there is a rattle in the front suspension. i have had all 4 struts and mounts replaced, the rack and pinion replaced, the pins in the calipers replaced and there stillis a rattle when you go over bumps aor rough roads. the people that replaced the struts tell me everything is tight but something must be loose. the lexus dealer tells me the coil spring insulator is bad but i can't believe that would cause a rattle as heavy as that car is. appreciate if you have any ideas. Lee
Feb 21, 2008 at 4:54 AM
2CARPRO JACK
  • 11,533 POSTS
Try replacing the sway bar end links. They can appear ok, but wil make noise when hitting bumps, sounds like you have already tried most everything else
Feb 21, 2008 at 7:18 AM
