1993 Lexus LS 400 engine??
1993 LEXUS LS 400
148,641 MILES • V8 • 2WD • AUTOMATIC
TWINKLE
car is turning over but it is not starting
Jul 11, 2010 at 9:32 PM
What you need to do is determine if its a fuel or spark problem that's preventing it from starting-Do below:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Jul 11, 2010 at 10:29 PM
