1993 Lexus LS 400 cant figure out why pedal goes to the flo
1993 LEXUS LS 400
200,000 MILES • V8 • AWD • AUTOMATIC
SPOOKEYDOOKIE
just replaced front brakes because they were pulling to one side. got those on and bled the brakes and pedal was really spongy after bleeding. so i bought a master cylinder hoping that would fix it and went through the whole process of bleeding brakes and master cylinder and still pedal is really spongy have any advice
Sep 30, 2009 at 8:25 AM
If there's no leak anywhere-could be a bad master cylinder or if you have an ABS unit could be coming from there.
Sep 30, 2009 at 8:43 AM
SPOOKEYDOOKIE
like i said i already replaced master cylinder and theres no leaks. do the brake pad sensors have to be hooked up?
Oct 1, 2009 at 10:53 AM
You sure its not the M/C I've done new ones and end up being defective has an internal leak in it not maintaining the hydraulic pressure. Do you have an antilock brakes? If so could be it causing the problem. The sensor has nothing to do with a spongy brakes-
Oct 1, 2009 at 11:00 AM
SPOOKEYDOOKIE
i just spent 230 some dollars on a BRAND NEW master cylinder! could it be the brake booster? and of course i have anti lock brakes most modern cars do....
Oct 1, 2009 at 2:14 PM
Check and test the brake booster and the ABS unit don't work bring it in for further diagnosis
Oct 2, 2009 at 2:44 AM
