1992 Lexus LS 400 Tire noise turning right
SIERRASIERRA
  • 9 POSTS
Noises problem
1992 Lexus LS 400 V8 209000 miles
Noise when making a right turn. Not very loud. Regular and repetitive. Maybe 4 or 5 noises per turn. Noise increases at the peak of the cornering radius and then stops for the rest of the turn. Ends too quickly to tell whether it's coming from the front or back, but unmistakably from driver's side of vehicle. Noise greater in steeper turns. No noise when going constantly around to the right. No noise when turning left.
Jun 4, 2009 at 5:44 PM
MERLIN2021
  • 17,250 POSTS
What type of noise? Banging? Clicking? Grinding? How would you catagorize it?
Jun 5, 2009 at 7:46 AM
SIERRASIERRA
  • 9 POSTS
It's not banging. Kind of a grinding sound spaced regularly apart. Not a winding grind, but short.
Jun 5, 2009 at 8:14 AM
MERLIN2021
  • 17,250 POSTS
When was the last time the brakes were looked at?
Jun 5, 2009 at 8:16 AM
SIERRASIERRA
  • 9 POSTS
Just bought it used so don't know but there's still brake pads left. No noise when braking in a straight line. Brakes well.
Jun 5, 2009 at 8:20 AM
MERLIN2021
  • 17,250 POSTS
Worth a look, it could be a hub bearing, and have those checked at the same time...
Jun 5, 2009 at 8:44 AM
SIERRASIERRA
  • 9 POSTS
Bingo! The front left hub bearing had some play. Thanks a lot.
Jun 5, 2009 at 11:33 AM
MERLIN2021
  • 17,250 POSTS
Anytime!
Jun 6, 2009 at 3:03 AM
