1992 Lexus LS 400 Power steering has clogged and died
230,000 MILES • V8 • FWD • AUTOMATIC
DWRICHY
My power steering started getting clogged. I used to be able to solve the problem by flushing the fluid out the bottom after removing the solenoid valve, but that seems to be no longer effective. Power steering pump was replaced with a refurbished one about 3.5 years ago. What could the problem be?
Mar 9, 2009 at 10:03 AM
RACEFAN966
  • 5,029 POSTS
How do you mean cloged? What is it doing or not doing?
Mar 9, 2009 at 10:21 AM
DWRICHY
It's as if the power steering goes out. It's very difficult to turn the steering wheel when the car isn't in motion.
Mar 9, 2009 at 10:32 AM
RACEFAN966
  • 5,029 POSTS
Ok this car has a power steering ECU. This is a computer more less that controls the power steering pressure. It is what tells the power steering pump to come on when turn the wheel. If you have a digital multi meter we can test this ECU. Get back to me with what you would like to do.
Mar 9, 2009 at 11:31 AM
