Engine Mechanical problem
1991 Lexus LS 400 V8 Two Wheel Drive Automatic 200k miles
oil pressure light going off and on, slight rattling on excelleration wiyh a lose of power
Wednesday, May 5th, 2010 AT 10:09 PM
MECHANIC
Hi there,
The first thing that you need to do is get the oil pressure tested with a mechanical gauge, lets see what the actual pressure is first, start here.
Mark (mhpautos)
SPONSORED LINKS
Wednesday, May 5th, 2010 AT 10:30 PM
HOFF19580
MEMBER
Thanks. The oil pressure is about 75psi. What's next?If you can help me fix this I will certanly make it worth your wild.I realize time is money. Thanks again!
Thursday, May 6th, 2010 AT 7:05 PM
MECHANIC
OK, oil pressure sounds fine, so I would be replacing the pressure switch, no I would get a scan done and look for a faulty knock sensor, as I feel it is a timing issue causing this rattle, if it is there under acceleration, I would be fairly sure that we may be looking at a knock sensor,
