1991 Lexus LS 400 NO POWER TO THE INSIDE OF THE CAR
CARRIEDEVANE
  • 6 POSTS
Electrical problem
1991 Lexus LS 400 V8 Automatic
After replacing the fuse for the alternator, my car will start, but, nothing electrical will work now....I can't shift gears, the windows and moon roof do not work, the door locks, radio, panel lights....nothing is working...and it will not shift out of park....this is my only means of transportation and I am a single mother trying to make it and now my car is doing this, I can't afford to take it to a shop to be diagnosed or repaired, nor do I have a way to get it anywhere to be looked at since it won't even go into drive...If anyone has any idea of what I need to check or replace or try....please please let me know...I am LOST....Thank you so much.....
Sep 16, 2008 at 6:20 AM
  • 75,988 POSTS
I you don't see those lights that you normally see when key is at On-you have a power problem between the battery and ignition switch-start checking all the fuse links and miniature ones.
Sep 16, 2008 at 7:43 AM
