1991 Lexus LS 400 Nakamichi Stereo Problem
WYOHERBTY
  • 1991 LEXUS LS 400
Electrical problem
1991 Lexus LS 400 V8 Two Wheel Drive Automatic
How can you determine whether the stereo problem is with the amplifier or the receiver? My stereo plays and the CD plays, but sounds are all distorted.
1. What is the problem?
2. Is it worth replacing with a used OEM Nakamichi?
3. Where can I find a used OEM Nakamichi and what can expect to pay?
4. Or is it better to replace with a new stereo with blue tooth and iPod capability?
Thanks very much!
Herb
4.
Tuesday, April 28th, 2009 AT 9:17 AM
92LS
Its probably the wiring causing the distortion. These cars are old and you should check the wiring to see if the cables are good and not touching each other before anything else.
Monday, July 20th, 2009 AT 10:52 AM
