1991 Lexus LS 400 fuel pump switch
1991 LEXUS LS 400
210,000 MILES • V8 • 2WD • AUTOMATIC
MACKDADDY409
where can i find the fuel pump shut off switch
Mar 26, 2009 at 12:47 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Your vehicle is not equipped with an inertia switch.. inspect the fuel pump relay, located on the right front inner fender panel.
Thanks for using 2CarPros.com!
Mar 26, 2009 at 12:54 PM
MACKDADDY409
i replaced the relay,pump,filter,distributior caps,rotors,plugs n wires,battery,and still wont turn over
Mar 26, 2009 at 1:25 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Is fuel pump kicking in? Have you checked fuel pressure at rail and spark at plugs?
Mar 26, 2009 at 1:53 PM
