I'm having a coolant leak. It really seems to be leaking from the cover right behind the crank pulley which has a small square hole on the bottom of the cover. Is this a simple fix and a common problem? I would think it would be leaking from the water pump but doesn't seem so or from the radiator. I don't know why it would be leaking so far down on the motor by the oil pan behind the crank pulley. Could anyone please help? thanks L.K.
Mar 21, 2009 at 5:50 PM
