1991 Lexus LS 400
FUJIHANO
Engine Performance problem
1991 Lexus LS 400 V8 Automatic 98100 miles
Everytime I start or come to a stop while driving, the car keeps shaking. I purchased new coil, gave the car a tune up and I am at my wits end.
Feb 21, 2008 at 11:36 AM
2CARPRO JACK
  • 11,533 POSTS
Need to find out which cylinder is missing.If you can access the injector plugs, unplug them one at a time until there is NO change...that is the one. Do a compression test, if ok, use a meter to check the wire, if ok it is probably the injector. Try cleaning the Idle Air Control Motor.Also clean out around the butterfly in the throttle bore with carb cleaner and a rag.This should help stabilize the idle
Feb 21, 2008 at 11:20 PM
