1990 Lexus LS 400 power steering into injection system
150,000 MILES • V8 • 2WD • AUTOMATIC
VAN THE MAN
I have put all new hoses and pump on my 1990 LS400. Now the power steering fluid is getting blown through the vacuum lines into the fuel injection system. How is the systems tied together and how could I begin to repair this? I should tell you that I purchased this car with this problem and the previous owner could have done anything.
May 5, 2008 at 1:04 PM
BHOEFE
  • 6 POSTS
Did you ever get an answer to this...I am having the same issue with my 1990 LS 400.
Jul 7, 2008 at 12:14 PM
BHOEFE
  • 6 POSTS
Your air flow control sensor located on the bottom of the steering pump is bad and is letting fluid get sucked into the intake manifold through the 2 vacume lines attached.
Jul 14, 2008 at 12:12 PM
