1990 Lexus LS 400 overheating
DRUPYFLIMUSIK
  • 1990 LEXUS LS 400
  • V8
  • 200,000 MILES
Well I have a 1990 lexus ls400 and yesterday I found that my car started to overheat as I was driving home and after letting it be idle overnight I checked my fluids and found that I was completely out of antifreeze and the smoke that appeared smelled like coolant but I refilled the tank with water and coolant the car still was running hot. Extremly all the way to the H. What can I do to check this problem?
Thursday, September 30th, 2010 AT 11:12 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Check for cracked head gasket, with engine COLD and radiator full of coolant / water remove radiator cap. Crank engine over and if coolant blows out of radiator cap opening than you most likely have failed head gasket.
Thursday, September 30th, 2010 AT 11:34 AM
