1990 Lexus LS 400 Front Brakes engage while driving
150,000 MILES • V8 • FWD • AUTOMATIC
SHAWNWO
Last couple of days I felt a shimmy in the front, then today felt like a drag on the vehicle.. the front brakes engaged and did not release, both sides were smoking hot, I let it cool and did not have the problem the rest of the ride, but it was not the first time during these last few days.. what should I check?
Oct 24, 2008 at 10:12 PM
MASTERTECHTIM
  • 4,750 POSTS
with both fronts locking up i would not suspect caliper or brake hose problems, i would look closely at the brake pedal under the dash to make sure the brake light switch is not holding the brake pedal down a little. you can try pulling on the brake pedal and see if you hear a couple clicks, that would be the brake switch adjusting. also look under dash and see if maybe a alarm module or some wiring is caught behind brake pedal where the brake light switch is. hope this helps
Oct 24, 2008 at 10:29 PM
