2002 Lexus IS 300 Timing Belt Replacement
11,400 MILES • 6 CYL • 2WD • AUTOMATIC
DAVID STEFFES
I'm replacing the timing belt and can't seem to get the crankshaft bolt loosened to remove the belt drive pulley and damper. I've been trying with a 1/2" impact. Is the bolt standard or reverse threaded and is a 1/2" impact wrench strong enough for the job?
Jun 29, 2008 at 4:33 AM
  • 75,988 POSTS
Try using a breaker bar, brace it securely in place and crank engine over-think safety-
Jun 29, 2008 at 6:52 AM
