2001 Lexus IS 300 transmission fluid leak
2001 LEXUS IS 300
81,000 MILES • 6 CYL • 4WD • AUTOMATIC
IS300_TLM
My Lexus IS300 the transmission fluid is leaking underneath the transmission pan. I went to PEPBOY to get a check up. The mechanic person told me that the transmission line fitting was where it leak. They unable to help me with that situation, but told me to go to a transmission shop or to LEXUS dealer. Is there a way that i could fix the problem by myself?. Or can I use a sealing silicone from AUTOZONE, PEPBOYS, or any other parts store to seal that leaking?. Please let me know. I would be more than happy to appreciate you.
Sep 14, 2008 at 2:34 AM
  • 31,937 POSTS
Hi there,
you will need to get this leak repaired correctly, those sealants wont do anything, i suggest that you get to a trans shop and get it attended to.
mark (mhpautos)
Sep 14, 2008 at 4:17 AM
