2001 Lexus IS 300 Swishing Sound
2001 LEXUS IS 300
137,000 MILES • 6 CYL • 2WD • AUTOMATIC
RDPR3
My car's tempeture gauge will start to go up now and again past the normal temp. The only way to make it go back down is to make a sharp turn or hit a bump in the road. When I do this I can hear a swishing sound of liquid from inside the car and the tempeture goes back to normal. I'm thinking it's a partial block in the cooling system but not sure if or how i can fix it. Please advise.
Jun 7, 2010 at 12:33 AM
2CARPRO JACK
  • 11,533 POSTS
Is the cooling system full? The swishing sound may be air being pushed around by the coolant.If you suspect a partial blockage, find a local radiator shop and they can do a backflush and flow check of the cooling system.
Jun 7, 2010 at 4:26 PM
