Steering problem
2001 Lexus IS 300 65000 miles
Hi, I recently received an esimate for an accident. But I suspect not all of the work items cited are related to the accident. This is important because of claim issues. Your help is needed ASAP, by this Weds, April 21.
Description of accident:
The car went over a pothole. The front left wheel of the car took the greatest impact. There was a very loud bang when the car was over the pot hole, and immediately, the steering felt as if it’d lost control of the wheel. I could steer it left and right without feeling a corresponding movement from the car. I stopped the car right after the intersection. Visual inspection showed that the two front wheels were not pointing at the same direction. The front left wheel was off to the counter-clockwise direction by a few degrees.
Please let me know what items below are related to the accident, and what is not. And please provide an estimate on the repair for the relevant items only.
FYI, the car is a 2001 Lexus IS300. I live in NY 11385. My email is wai_shiu@yahoo.com
Thank you for the help. I'd like to provide a $10 donation to your wonderful website.
This is the work list given to me by the shop:
THIS VEHICLE HAS EXCESSIVE DAMAGE TO THE FRONT END OF THE SUSPENSION:
LEFT FRONT SHOCK(DAMAGED),
LEFT FRONT SHOCK MOUNT(DAMAGED),
LEFT FRONT STEERING KNUCKLE(DAMAGED),
LEFT FRONT HUB(DAMAGED),
LEFT FRONT HUB BEARING(DAMAGED AND EXCESSIVE PLAY),
LEFT AND RIGHT FRONT LOWER CONTROL ARMS(DAMAGED AND EXCESSIVE PLAY),
LEFT AND RIGHT LOWER CASTER ARMS(DAMAGED AND EXCESSIVE PLAY),
LEFT AND RIGHT LOWER BALL JOINTS(EXCESSIVE PLAY),
STEERING RACK(DAMAGED AND EXCESSIVE PLAY),
ONCE ALL SUSPENSION WORK IS COMPLETED, VEHICLE WILL NEED A 4 WHEEL ALIGNMENT TO SET SUSPENSION PROPERLY.
ATF FLUID NEEDS TO BE FLUSHED OUT AS WELL,
BATTERY IS LEAKING ACID AND TERMINAL NEEDS TO BE REPLACED,
COOLANT TEMPERATURE SENSOR HAS INTERNALLY FAILED,
T/BELT IS CRACKED,
SERPENTINE BELT IS CRACKED
T/BELT IS CRACKED,
Apr 19, 2010 at 3:46 AM
