2006 Lexus IS 250 Frequent Brake and Tire Replacement
2006 LEXUS IS 250
49,000 MILES • 6 CYL • 2WD • AUTOMATIC
JENSLEXUS
I purchased my lexus used with 7,400 miles in Oct 2006. Since then I've replaced the brakes 3X (going on 4th) and the tires 3X. (to date I've racked up 49,000 miles). Is this normal?
Sep 16, 2009 at 12:26 PM
  • 31,937 POSTS
Hi there,
This is rather excessive, i would make sure that the alignment is correct and have the brake pressures tested, also make sure that quality brake pads are fitted, as cheap pads will cut out very quickly.
Mark (mhpautos)
Sep 16, 2009 at 12:30 PM
