1998 Lexus GS 400 Catalytic Converters
RBALDREE
  • 1998 LEXUS GS 400
  • V8
  • 122,000 MILES
I had both Cats replaced at 60,000 miles. The car now has 122,000 and the check engine light is once again indicating that the Cats are bad. The car runs great, good power, mileage is fine, no odd noises or smells, etc. Other than the check engine light coming on I wouldn't know that anything is wrong. I have never heard of catalytic converters only lasting 60,000 miles. Is there some other problem or possible issue here?
Tuesday, February 3rd, 2009 AT 11:51 AM
KEVINSTOYOTALEXUS
  • 5 POSTS
Hi RBaldree -
Did you ever find out what was causing your check engine light to go on? I also have a 98 Lexus GS400.
It does sound strange for the cats to go out after 60,000 miles especially if they are the Lexus cats. There are other things which can make it appear the cats are failing. The most important thing to do is to find someone who has an OBD2 scanner and plug it in under the dash below the steering wheel. You want to be able to access the freeze frame data. That is the data which was captured at the time the light went on and the code was set. By the way, what was the code? Did the light flash or just remain on? You may only have 1 side causing the error. The data and code will remain as long as the light is on. Once you have the data, post it and some one might be able to steer you in the right direction.
One note - have the spark plugs been changed? If not, on the scanner, look for misfire data. It could indicate a marginally running cylinder.
Hope this helps.
- Kevin
Monday, May 4th, 2009 AT 6:58 PM
