2008 Lexus GS 350 oil filter
2008 LEXUS GS 350
9,000 MILES • 6 CYL • AWD • AUTOMATIC
JOVAR84
oil filter on gs 350 where is that located on the engine i look all over the engine i could't find it please help if you can show me a diagram that really helpful
Jan 26, 2009 at 1:13 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Sorry, your vehicle is really new and I can not locate a diagram for you. I do have a description of location though. From underneath the car on the passengers side near the front there should be 2 bolts with 10 mm heads on a plastic panel about 5 inches square. Remove those bolts and you will see a shiny metal disc about 2 inches in diameter with a 3/8 inch square hole. Removing this plug will drain the filter, then using a large oil filter wrench you remove the cartridge cover. Inside is the oil filter. It is a cartridge only, the cover is reused. It is not like a twist on filter normally used.
Hope this helps..
Thanks for using 2CarPros.com !
Jan 26, 2009 at 5:52 PM
NYC.ECHO.LEXUS.TECH
  • 20 POSTS
IF YOUR UNDER YOUR VEHICLE THERE IS A FLAP HELD IN BY A 10 MM SCREW REMOVE THAT COVER/ FLAP
AND THE CANISTER COVER IS THERE UNSCREW THE COVE AND YOU HAVE A OIL ELEMENT
WICH IS A FILTER , MAKE SURE TO CHANGE THE O RING AND DO NOT OVER TOURQE 12FT/LBS
Jan 27, 2009 at 11:17 AM
