2000 Lexus GS 350 will not shift into high gear at high spe
2000 LEXUS GS 350
MARK DEPAN
Transmission problem
2000 Lexus GS 350 6 cyl Four Wheel Drive 120000 miles
my girlfriends lexus will not shift into high gear on the highway. car runs normally. all shifting is nornal until you are on the highway and then it will not shift into high gear even at 4000 rpm.
Jan 13, 2009 at 3:03 AM
2CARPRO JACK
  • 11,533 POSTS
Will go into High gear if you manually shift it? Is the check engine light on? regardless you may want to have the PCM scanned for any trouble codes it may have recorded. Usually iit is computer controlled item thPCM will see the failure and record a code. Does the speedo work properly?
Jan 15, 2009 at 12:10 AM
MARK DEPAN
no there are no codes and it will not shift into high gear manually.
Jan 16, 2009 at 4:57 AM
2CARPRO JACK
  • 11,533 POSTS
The you may need to find a trans shop or other that has the ability to override the computer and work the solenoid for 3rd gear.Sounds like it isnt working
Jan 16, 2009 at 6:29 AM
