2006 Lexus GS 300 Vehicle stability control system
53,000 MILES • 6 CYL • 2WD • AUTOMATIC
TAKADIVE
If the traction control system malfunctions and the slip indicator light and brake system warning light come on could it be a fuse? Does system have a fuse and were would it be? There are several fuse boxes on this vehicle. Could it have anything to do with brake replacement? 3 days ago the brake indicator came on, 2 days ago the vehicle stability control system warning came on. Yesterday I had the rear brakes replaced. The brake indicator went out but not the VCS warning, could there be a reset for the vehicle stability control indicator?
Feb 10, 2010 at 8:03 AM
2CARPRO JACK
  • 11,533 POSTS
For all of them to light up is most likely a failure in the system, not likely to be a fuse.You should have the system scanned to see what codes the computer has stored.May be something as simple as a wheel sensor, but a scan will point us in the right direction.If the lights were on 2 days ago, then brakes were done yesterday, its not likely the cause of the problem
Feb 10, 2010 at 8:29 AM
