1999 Lexus GS 300 Power Brake Failure and Warning Lights
1999 LEXUS GS 300
82,000 MILES • 6 CYL • 2WD • AUTOMATIC
BOBS300
MEMBER
1 POST
My power brakes stopped working suddenly and I have the following warning light lit on the dash: BRAKE, ABS, VSC, VSC Off.
Oct 26, 2009 at 12:03 AM
SERVICE WRITER
✓Experienced Mechanic
Do you have any brakes?
IF no,
Check the mastercylinder for a fluid level drop as there may be a leak.
If yes,
You need to retreive the codes from the abs module to go further.
Oct 26, 2009 at 12:17 AM
