1998 Lexus GS 300 blower
1998 LEXUS GS 300
TIMINATOR2000
Air Conditioning problem
1998 Lexus GS 300 6 cyl Two Wheel Drive Automatic
This is really a two part question.
1st. If the a/c is still blowing cool air it's just not going to full speed does that mean the motor is going out or just the top 1 or 2 speeds no longer works? If so is it rather easy to just replace the motor?
2nd. This deals with the auto door locks and remote door lock/unlock. A few of the doors won't automaticlly lock. I changed out the battery on the remote but they don't even work from the inside door switch. I have to manually flip them. Is it a cylinoide that has gone bad and needs to be replaced?
Thanks,
Tim P
Oct 8, 2008 at 9:04 AM
2CARPRO JACK
  • 11,533 POSTS
Sound sliek the fan speed resistor is going bad, itis located int heplenum next to th efan motor. Yes it sound sliek th edoor lock actuators are not working, but you will need to take the door panels off to test for power to verify this
Oct 8, 2008 at 10:07 AM
