1994 Lexus GS 300 I replaced the 100 amp alt fusible link.
1994 LEXUS GS 300
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
RW2JASE
I replaced the 100 amp alt fusible link. And now it does nothing.I have no idea whats wrong.Before I changed it, at least it ran .But after I put the fuse in I hooked everything up, as it was, and I have nothing...Its not getting any juice from the battery for some reason. And the battery is charged, I even tried the battery out of my truck just to make sure..... Any help would be great!!!
Oct 8, 2008 at 11:10 AM
IMPALASS
  • 3,112 POSTS
Hi – take a volt meter and insert one end of the probe on one side of the link and the other on the other side through the wire. Make sure you have contact with the metal wire inside then see if you are getting any voltage through the link. Let us know what you find.
Oct 8, 2008 at 2:31 PM
