2005 Lexus ES 330 Trunk Remote Button
48,000 MILES • 6 CYL • 2WD • AUTOMATIC
DICK TEMPLE
The dashboard remote trunk button no longer works. The key fob is the only way to open the trunk. Thank you....
Aug 13, 2010 at 4:42 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Check fuse labeled DOOR1 (25 amp) , if it's good then the switch is most likely at fault and needs replaced.
Aug 13, 2010 at 7:32 AM
