Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Lexus
ES 330
Body
Trunk
Switch
2005 Lexus ES 330 Trunk Remote Button
2005 LEXUS ES 330
48,000 MILES • 6 CYL • 2WD • AUTOMATIC
DICK TEMPLE
MEMBER
1 POST
The dashboard remote trunk button no longer works. The key fob is the only way to open the trunk. Thank you....
Aug 13, 2010 at 4:42 AM
BLUELIGHTNIN6
Experienced Mechanic
Check fuse labeled DOOR1 (25 amp) , if it's good then the switch is most likely at fault and needs replaced.
Aug 13, 2010 at 7:32 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Transmission — Not Shifting
