2003 Lexus ES 300 headlights
FYRITE12
Electrical problem
2003 Lexus ES 300 4 cyl Two Wheel Drive Automatic
I am having trouble with my left headlight. It all of a sudden quit working. I changed the bulb. Didnt help. I checked the fuse for the left headlight it was good. I tested the fuse connection with a 12 volt tester and I had power. I tested the outlet and there was no power. Got any ideas?
Oct 20, 2010 at 11:17 AM
SERVICE WRITER
  • 9,123 POSTS
Both hi and low are out on that side? Everyone in a while I run into a bad bulb that is new, just be sure the bulb is good before hairpulling.
https://images.2carpros.com/forum/automotive_pictures/30961_lex_2.jpg
I can send you the diagram if you can not read it.
Oct 20, 2010 at 10:13 PM
