2002 Lexus ES 300 engine misfire cilinder1,3,5
2002 LEXUS ES 300
119,500 MILES • 6 CYL • FWD • AUTOMATIC
RONALDSARTI
check engine ligth is on and trac vsc
Jul 25, 2009 at 2:41 PM
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Jul 25, 2009 at 5:07 PM
PBRMERFN
Had same issue with 96 camry with 3.0 v6. tried all those things on speculation also. Found the timing for the rear bank was lined up with the tab of the timing cover rather than the timing mark!!!!!!!!!! about a cm away. adjusted cam timing, then within 6 months had both knock sensors fail.
Dec 12, 2009 at 4:10 PM
