2002 Lexus ES 300
2002 LEXUS ES 300
EJDICE
  • 6 POSTS
Engine Mechanical problem
2002 Lexus ES 300 6 cyl Front Wheel Drive Automatic
car will not start after sitting a couple of days battery checks out fine
Feb 26, 2010 at 5:26 AM
Pick your symptom:
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
No crank at all/nothing/nada:
Could be the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
Feb 26, 2010 at 11:17 AM
