HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Lexus
ES 300
Engine
Symptoms
Not Running
2001 Lexus ES 300 CAN NOT START ENGINE
LACMYTRAN2003
MEMBER
2001 LEXUS ES 300
6 CYL
2WD
AUTOMATIC
89,000 MILES
I REPLACE NEW BATTERY BUT IT CAN NOT START ENGINE EITHER.
SINCERELY
Thursday, July 24th, 2008 AT 1:41 AM
MECHANIC
Do you mean it cranks engine over but refuses to start or won't crank at all. Latter part could be the Anti Theft Deterrent Device
Thursday, July 24th, 2008 AT 1:48 AM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
Refused To Start
My Es300 Overheated And Stopped On Me On The Highway Fresh From The Car Shop. I Just Had The Fuel Pressure Regulator Replaced @ $420. Before...
Asked by
samhoustonstar
1996
LEXUS ES 300
VIDEO
Car Cranking but Not Starting? Try This
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
Car Will Not Start At Certain Times And Then Sometimes...
I Have Replaced The Electric Fuel Pump And Fuel Filter. After Doing This The Car Started The First Time. I Then Tried To Start The Car Again...
Asked by
Don1
1996
LEXUS ES 300
1994 Lexus Will Crank But Not Start
The Car Will Crank But Not Start. The Ecu Has No Power, Scanner Will Not Connect To Vehicle, No Spark, Fuel Pump Does Not Come On...
Asked by
anitalj44
2 IMAGES
1994
LEXUS ES 300
2000 Lexus Es 300 Car Wont Start
I Have A 2001 Es300, Today Car Started Running Rough Then When I Stopped, The Car Cut Off And Will Not Restart, Cranks And Shut Back Off...
Asked by
bigge
2000
LEXUS ES 300
1994 Lexus Es 300 Car Won't Start, Nothing When Key...
Car Won't Turn Over And Headlights Won't Come On. Headlight Fuses In Engine Compartment Fuse Box Are Fine But They Are Not Getting Any...
Asked by
jstrom22004
1994
LEXUS ES 300
VIEW MORE
How to fix an engine that wont start
Crankshaft Sensor Replacement
