2000 Lexus ES 300 idle
160,000 MILES • 6 CYL • FWD • AUTOMATIC
ANDFRAN
Will not idle
Aug 23, 2010 at 5:53 AM
WRENCHTECH
  • 20,760 POSTS
You may have a bad IAC ( idle air control) but try cleaning the throttle body first. Remove the intake snorkel, have someone hold the throttle wide open for you and scrub the back side of the throttle plate and surrounding bore with an old tooth brush and some carb cleaner. Be sure to spray some into the small holes next to the throttle plate. That should help stabilize the idle. If it still has a problem, replace the IAC.
Aug 23, 2010 at 6:07 AM
