1999 Lexus ES 300 stalls shifting now and then
100,000 MILES • 6 CYL • FWD • AUTOMATIC
JOELRICHARDSON
stalls shifting now and then once or twice then shifts ok,no check eng light,no trsm slip,goes in gear a little hard some at fast idle,slow to go in overdrive cold
Feb 22, 2010 at 3:48 AM
2CARPRO JACK
  • 11,533 POSTS
Start with a service using the factory fluid.If no faults are being set, it may be a mechanical issue inside it instead of electronic.If that is the case, you will need to have a trans shop do some line pressure checks to see where the problem lies
Feb 24, 2010 at 12:02 AM
