how do i adust idle speed on 1998 lexus es300. when starting i must start car and rev gas or if i just start it will idle to low and turn off
Jul 27, 2008 at 8:50 AM
BMRFIXIT
✓Experienced Mechanic
No adjustment
remove and clean idle air Control valve
Jul 30, 2008 at 11:40 PM
MYESLCLASS
MEMBER
[quote:041194c50f="BMRFIXIT"]No adjustment
remove and clean idle air Control valve[/quote:041194c50f]
Did you change oil, air fitler?
Yes you can increase the idling by turn it up with a screw driver. But most of the time , the problem is the idle air control dirty or fault.
