1998 Lexus ES 300
1998 LEXUS ES 300
KIMMYKIM67
Suspension problem
1998 Lexus ES 300
How do you remove the front wheel hubs for bearing replacement?
Jun 28, 2008 at 4:21 AM
MASTERTECHTIM
  • 4,750 POSTS
is it a hub and bearing assembly you are replacing or just the bearing itself?
Jun 28, 2008 at 4:34 AM
KIMMYKIM67
It is just a bearing assembly
Jun 28, 2008 at 4:45 AM
MASTERTECHTIM
  • 4,750 POSTS
this is a very tricky job even for a mechanic and involves using bearing press. for a back yard tech to do job i would recommend removing entire spindle and bring it to a machine shop and have them install the bearing and then you can reinstall the assembly, its probably the cheapest way out and the easiest.
Jun 28, 2008 at 5:17 AM
