1995 Lexus ES 300 engine stay running
1995 LEXUS ES 300
34,560 MILES • 6 CYL • 2WD • AUTOMATIC
KKATT55
had a ignition module installed and the problem is not solved, after it is switch on and heated up .
Feb 28, 2010 at 4:08 PM
LEGITIMATE007
  • 5,121 POSTS
you must verify first that you have fuel pressure and spark. to narrow this down, I will send video to show you how
Feb 28, 2010 at 10:56 PM
LEGITIMATE007
  • 5,121 POSTS
here is the spark
https://www.2carpros.com/how_to/how_to_test_an_ignition_system.htm
Feb 28, 2010 at 10:58 PM
LEGITIMATE007
  • 5,121 POSTS
here is the fuel pressure
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Feb 28, 2010 at 10:59 PM
