Hi! I just bought this 94 lexus es300. I failed emission test because of too much Hydrocarbons according to emission result paper. I was trying to stop that smoking anyways, so I replaced all valve seals and head gasket. Meanwhile, I found transmission fluids inside the intake. I know there is two vacuum lines on p/s hose. After I reaplaced all valve seals and head gasket, the problem is still there. (Smoking! It starts with white smoke and turns to blue smoke)
Question : Do you think that smokin is somehow related with p/s line?? (2 vacuum lines go to the intake and I found trans fluid inside the intake!)
I was also noticed that p/s fluid drop down so quickly,
(I also changed p/s pressure hose.)
Nov 15, 2008 at 9:56 PM
