1994 Lexus ES 300 no spark to 3 cylinders
1994 LEXUS ES 300
175,000 MILES • 6 CYL • FWD • AUTOMATIC
TOBO1201
  • 6 POSTS
i am only getting fire to the number 1,2,& 4 cylinders
i have checked the coils & plugs and changed out the ignitor & ecu but still have same problem
the car will start and idle rough on 3 cylinders
i do have 12 volts to all the coils
Jun 9, 2010 at 5:07 AM
Hi tobo1201, Welcome to 2carpros and TY for the donation
Check and test the plug wire for no.3 and also the crankshaft position sensor
Jun 9, 2010 at 6:30 AM
TOBO1201
  • 6 POSTS
i am not getting fire to 3 cylinders not just the #3 cylinder it does not have plug wires it ihas a coil for each cylinder the coils and plugs are all good
Jun 9, 2010 at 1:21 PM
I thjought its only no.3 okay check and test the crankshaft positon sensor
Jun 9, 2010 at 2:33 PM
TOBO1201
  • 6 POSTS
i have already changed the camshaft sensor and i get good signal to ecu from the sensor
Jun 9, 2010 at 8:58 PM
Did you check the CPS
Jun 9, 2010 at 9:24 PM
