1994 Lexus ES 300 ECM wiring harness
1994 LEXUS ES 300
ANITALJ
Electrical problem
1994 Lexus ES 300 6 cyl Automatic 220,00 miles
I have a 1994 Lexus es300 that will start then stop. I had the car in the shop for 2 months and they can't find the problem. They told me that it is most likely the computer. I purchased a re-built ECM to install in the car. When I took the old computer out one of the plug-ins had a brown greasy substance going down just that plug-in. The other wires were clean and dry. Is it possilble that there is a problem with the wiring harness?
Feb 1, 2009 at 4:25 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
I would be thinking more a problem with the ECU. if you can give me the pin code and the wire colour code i can check the schematic and see what this with is controlling, but as i said i feel more a ECU problem that a loom issue.
Mark (mhpautos)
Feb 1, 2009 at 6:33 PM
ANITALJ
I have replaced the ECM twice and it still does not work correctly. I will get the pin code and color code.
Feb 1, 2009 at 11:41 PM
