Car won't turn over and headlights won't come on. Headlight fuses in engine compartment fuse box are fine but they are not getting any current. Regarding starter, no current at starter. When I connect directly from battery to starter car will start. Must be a relay somewhere between ignition switch and starter. I've checked all fuses and the starter fuse is good but it's not getting any power/current unless I connect a lead wire directly from battery to the wire that goes to the starter solenoid. I've checked the fuse box under the driver's side dash and all are ok. Ignition fuse gets power when key is turned to on position. I could sure use your help on this!
Regards,
Jim
SPONSORED LINKS
Saturday, March 28th, 2009 AT 11:46 PM
